> I can't play
Salade au thon
post Dec 23 2011, 04:48 PM
Yesterday I bought RoA. It's look very fun.
But...
When I start the Game, I get the initial splash screen that says Rock of Ages. Then the screen become black for 5sec then and finally ending with a Windows event stating "RoA.exe has stopped working" huh.gif
I tried all, really all.
I tried that :
https://support.steampowered.com/kb_article...=5688-IFHZ-2170
that :
http://support.steampowered.com/kb_article...=2037-QEUH-3335
that :
http://support.steampowered.com/kb_article...=6218-USFX-5568
and that :
https://support.steampowered.com/kb_article...=9257-TUJL-7421
But that's sill not working...
I really want to play this game, no, I neeeeeeed to play this game !! smile.gif
Help me !!
post Dec 23 2011, 08:20 PM
What are your computer's specs?
Salade au thon
post Dec 24 2011, 09:44 AM
OS : Microsft Windows 7 édition familile Premium
PC : ASUS Tek Computer Inc.
Processor : Pentium® Dual-Core CPU T4400
Country : France
Graphic : Nvidia Geforce GT 320M
post Dec 25 2011, 10:36 AM
Have you looked for info in the Steam Rock of Ages forums?
Here's the bug list report thread:
http://forums.steampowered.com/forums/show...d.php?t=2105181
Apparently it's a Windows issue. People that have reported startup crashes are always using Vista or Windows 7.
Salade au thon
post Dec 25 2011, 04:36 PM
Yes, many poeple have the same problem but nobody find a solution.
LOGS :
CODE
[0000.21] Init: Computer: FRANÇOIS-PC
[0000.21] Init: User: François
[0000.21] Init: CPU Page size=4096, Processors=2
[0000.21] Init: High frequency timer resolution =2.148496 MHz
[0000.21] Init: Memory total: Physical=4.0GB Pagefile=8.0GB Virtual=4.0GB
[0000.36] Log: STEAMWORKS initialized 1
[0000.36] Log: IsCooking 0, bisEditor 0
[0000.36] Log: Game available languages: english,french,german,italian,japanese,spanish,russian
[0000.36] Log: Steam language: french
[0000.36] Init: Presizing for 33476 objects not considered by GC, pre-allocating 0 bytes.
[0000.36] Init: Object subsystem initialized
[0000.37] DevDataBase: Connection to "Provider=sqloledb;Data Source=production-db;Initial Catalog=EngineTaskPerf;Trusted_Connection=Yes;Connection Timeout=2" or "10.1.20.20" failed
[0000.81] Log: Shader platform (RHI): PC-D3D-SM3
[0000.90] Log: PhysX GPU Support: DISABLED
[0003.81] Warning: Warning, Failed to load Outer for resource 'isFullGame': Class OnlineSubsystemNP.OnlineSubsystemNP
[0003.81] Warning: Warning, Failed to load Outer for resource 'ReturnValue': Function OnlineSubsystemNP.OnlineSubsystemNP:isFullGame
[0007.41] Log: 68312 objects as part of root set at end of initial load.
[0007.41] Log: 0 out of 0 bytes used by permanent object pool.
[0007.41] Log: Initializing Engine...
[0007.42] Log: OSS: Steamworks
[0010.77] Log: Initializing Steamworks
[0010.77] Log: Logged in as '[ZS] Salade au thon'
[0010.82] Log: LoadMap: BoulderFrontEnd?Name=Player?Team=255
[0011.09] Log: Game class is 'Boulder_GameFrontEnd'
[0011.17] Log: Primary PhysX scene will be in software.
[0011.17] Log: Creating Primary PhysX Scene.
[0011.17] Log: Bringing World BoulderFrontEnd.TheWorld up for play (0) at 2011.12.23-20.36.10
[0011.18] Log: Bringing up level for play took: 0.072694
[0011.28] Critical: appError called: SECURE CRT: Invalid parameter detected.
[0011.28] Critical: Windows GetLastError: Lopération a réussi. (0)
[0019.31] Log: === Critical error: ===
System.Runtime.InteropServices.SEHException error in RoA:
Un composant externe a levé une exception.
   à GuardedMainWrapper(Char* , HINSTANCE__* , HINSTANCE__* , Int32 )
   à ManagedGuardedMain(Char* CmdLine, HINSTANCE__* hInInstance, HINSTANCE__* hPrevInstance, Int32 nCmdShow)Address = 0x75deb9bc (filename not found) [in C:\Windows\syswow64\KERNELBASE.dll]
Address = 0x5a0f91   (filename not found) [in c:\program files (x86)\steam\steamapps\common\rock of ages\Binaries\Win32\RoA.exe]
Address = 0x5d2d93   (filename not found) [in c:\program files (x86)\steam\steamapps\common\rock of ages\Binaries\Win32\RoA.exe]
post Dec 25 2011, 05:43 PM
Have you tried verifying the cache?
Does it work if you run in English?
Salade au thon
post Dec 27 2011, 07:02 AM
I did, but it doesn't work.
post Dec 27 2011, 08:44 AM
Did you skip the DirectX setup on startup? If so please check out these threads:
http://forums.steampowered.com/forums/show...ghlight=directx
Also, check this info from another post at the Steam forums:
"Originally Posted by Mycologist
Ok, I've solved my issue, although I don't know if this is just a temp fix. Before launching the game, open the taskmanager and end the process called "taskhost.exe". Fixed it for me".
Source: http://forums.epicgames.com/showpost...3&postcount=12
RSS Lo-Fi Version Time is now: 23rd May 2013 - 03:42 PM
