> Coop Connection Issues, Unable to play coop with a friend
Lux
post May 27 2013, 12:57 AM
A friend and I have been trying to play for roughly an hour now and have been unable to connect.
We have tried the following (as per other recommendations)
- Play single player and after the first cut scene invite them to join you
- Make sure ports are forwarded (https://support.steampowered.com/kb_article.php?ref=8571-GLVN-8711&l=english)
- Try a bunch of console commands
The single player thing never worked. The ports listed are forward however that didn't work. I cant get the console to come up no matter what I try so I couldn't try the console command.
What type of black magic do I have to cast so that I can play with my friend? This has been an incredibly frustrating experience.
post May 27 2013, 03:33 AM
I don't think the console is enabled so that won't work.
How far away is your friend? Apparently the game has a built-in filter to disable coop games that have unacceptable latency.
Lux
post May 27 2013, 11:40 AM
QUOTE (tschumann @ May 27 2013, 03:33 AM) *
He lives maybe 30 minutes away. Can I disable this filter?
post May 27 2013, 01:45 PM
No, but if the game is filtering because of the connection speed, then if you did connect the experience would be unplayable.
Are you able to connect and play other games with relatively good connection (low latency) with your friend? I'm assuming you do, but better to ask.
Lux
post May 28 2013, 09:49 PM
QUOTE (Carlos Bordeu @ May 27 2013, 01:45 PM) *
We are able to play many games without an issue and do have low latency. We did a bit more fiddling and found that we are unable to find any games, private, public, or otherwise.
post May 28 2013, 10:30 PM
Did you both forward ports?
Lux
post May 30 2013, 09:19 PM
QUOTE (tschumann @ May 28 2013, 10:30 PM) *
We both forwarded the ports that where suggested on for steam games (as I linked in the OP). What ports should I focus on?
post May 31 2013, 02:46 AM
I think just the Steam Client ports I think.
Are you able to directly connect to each other's listen servers in Team Fortress 2 or something similar?
Lux
post May 31 2013, 06:31 PM
QUOTE (tschumann @ May 31 2013, 02:46 AM) *
Yes. We can with Garry's Mod, Minecraft, TF2. I will retry and make sure he has the ports setup at the same time as I do. He might have tried it and when it didn't work, took out the port forwarding.
post May 31 2013, 07:08 PM
Just to check, you're not doing this with dedicated servers are you?
Can you connect to your friend when he's the server and can he connect to you when you're the server too?
post Jan 30 2016, 07:31 PM
Just as an update, I think the latency limit is set by
[ZC2Game.PreLobby]
MaxGamePing=0.250
in ZC2Game.ini
