> throwing weapons freezes game
post May 31 2011, 02:38 AM
Whenever I throw a weapon in the map I'm working on, the game freezes. I've tried it with all the weapons and it freezes with all of them (except the torch which can't be thrown).
Is there something I need to do to make this work?
post May 31 2011, 09:04 AM
Oh my. It's been such a long time since any of us looked through Zeno Clash configurations in Source. I think there should be an entity that controls whether you're in combat mode or idle, and I think that has to be set (unless I'm mistaken and it defaults to something if it doesn't exist). Are your fists visible when the level loads? Can you throw punches? If you remember the 'throwing weapons' code was added as an update after we released the game, so we probably only tested it in level environments that were fully operational.
post May 31 2011, 07:02 PM
I executed the zenocombaton command through the console and I could see my fists. I don't think I could throw the weapons without that command.
post May 31 2011, 09:58 PM
Are you spawning the weapons with a command line or are they pre-placed in Hammer? Do both cases cause the same results?
post May 31 2011, 11:02 PM
They're placed in Hammer. I'll try it with the console.
post Jun 5 2011, 02:47 AM
Yeah same thing. It still freezes up.
I've got some .mdmp files if that helps.
post Jun 5 2011, 01:34 PM
QUOTE (tschumann @ Jun 5 2011, 02:47 AM) *
Send them to me and I'll check with David and see if I can find out why it is crashing. It has been quite a while since we use Source...
post Jun 30 2011, 02:53 AM
I think I've worked it out. I checked out the example map from the SDK and copied across the logic_auto (with Output OnMapSpawn,playerproxy,SetCombatMode,1,0.00,No) and and the logic_playerproxy named playerproxy, and it worked.
If you want to start without weapons then add another output to the logic_auto: OnMapSpawn,playerproxy,SetCombatMode,0,0.01,No (I didn't try setting it to 0 to start with, so it may work that way too).
post Jun 30 2011, 10:09 AM
QUOTE (tschumann @ Jun 30 2011, 02:53 AM) *
Congratulations on getting around the problem (and also for making me feel like something I knew before sounds like gibberish to me now laugh.gif )
post Jul 4 2011, 07:47 PM
Thanks. It's getting there slowly, but surely.
