> lightmaps
post Aug 14 2009, 08:40 PM
How exactly do lightmaps work? Do you need to add a second UVW layer to the model, then specify the material used for the the second UVW layer in the prop_static's entity data?
Or can you specify a lightmap for a model without a second UVW layer?
post Aug 14 2009, 09:46 PM
QUOTE (tschumann @ Aug 14 2009, 08:40 PM) *
This... exactly. Details documented in the wiki.
If you don't have a second UV layer I'm not sure if the lightmap will appear on as if it were on the first layer (or if it will just appear all messed up).
Anyways... a lightmap on the same UV layer as the diffuse makes no sense unless the prop uses a unique texture space for all its triangles. If it the regular diffuse (texture) layer has a tiling texture or mirror mapping, your lightmap would tile or mirror and completely look innapropriate.
Think of a large polygon with a tiling grass texture... For a lightmap for this 'prop' you would need a second UV layer where the polygon uses the texture area and does not tile.
Is this clear, or is my explanation too confusing?
post Aug 14 2009, 10:21 PM
Okay, I understand.
Do all the lightmap textures have sh in their names?
post Aug 15 2009, 02:29 AM
QUOTE (tschumann @ Aug 14 2009, 10:21 PM) *
Okay, I understand.
We did that so we could organize them better, but it's not mandatory. You can use any name you want.
