Aug 1 2009, 11:58 AM
#21
![]() Advanced Member ![]() ![]() ![]() Group: Members Posts: 688 Joined: 18-July 09 From: UK Member No.: 739 |
-------------------- Zeno Clash 2!
Aug 1 2009, 12:26 PM
#22
Member ![]() ![]() Group: Members Posts: 292 Joined: 24-July 09 From: Zenozoik Member No.: 750 |
I'll make Sun Spit if it works out well! HEHE, busted, Sun Crab, yellow crab, yellow ball, yellow spit... -------------------- |
Aug 1 2009, 01:38 PM
#23
HEHE, busted, Sun Crab, yellow crab, yellow ball, yellow spit... :/ -------------------- Zeno Clash 2!
Aug 1 2009, 07:37 PM
#24
![]() Advanced Member ![]() ![]() ![]() Group: Moderator Posts: 524 Joined: 20-March 09 From: Australia Member No.: 283 |
Aug 2 2009, 03:34 AM
#25
I found it, but I don't know how to change colour...
I'm not sure about changing the colours, but there's probably some information on the Valve Developer wiki. Yes, probably... Also, I would like to know why I can't see textures, any way to fix this?:
Aug 2 2009, 05:24 AM
#26
I found it, but I don't know how to change colour... Yes, probably... Also, I would like to know why I can't see textures, any way to fix this?: ![]() It's the Orange Box, it doesn't have the ZC textures. -------------------- Zeno Clash 2!
Aug 2 2009, 05:27 AM
#27
Will they show if I import them?
Aug 2 2009, 05:34 AM
#28
I copied my Zeno Clash materials folder to steamapps\<username>\portal\portal\materials and everything showed up alright.
Also, here's the model conversion program I wrote: http://cid-1bcc5bd24a241de4.skydrive.live....itch%20v1.0.zip Just drag and drop the .vvd file to convert it. |
Aug 2 2009, 06:09 AM
#29
I copied my Zeno Clash materials folder to steamapps\<username>\portal\portal\materials and everything showed up alright. Also, here's the model conversion program I wrote: http://cid-1bcc5bd24a241de4.skydrive.live....itch%20v1.0.zip Just drag and drop the .vvd file to convert it. So that will allow you to convert it for editing? -------------------- Zeno Clash 2!
Aug 2 2009, 09:06 AM
#30
Hmmm... Then we can add more stuff to Garry's Mod
Aug 2 2009, 09:59 AM
#31
Hmmm... Then we can add more stuff to Garry's Mod I want the Rubik's cube and Metamoq's helmet ^^ -------------------- Zeno Clash 2!
Aug 2 2009, 01:30 PM
#32
![]() Super Member ![]() ![]() ![]() ![]() Group: Developers Posts: 1,920 Joined: 11-April 08 From: Santiago, Chile Member No.: 4 |
I copied my Zeno Clash materials folder to steamapps\<username>\portal\portal\materials and everything showed up alright. Also, here's the model conversion program I wrote: http://cid-1bcc5bd24a241de4.skydrive.live....itch%20v1.0.zip Just drag and drop the .vvd file to convert it. This effectively converts ZC models to Source, right? Cool. If so we might consider adding this as a tool in the Wiki... |
Aug 3 2009, 02:44 AM
#33
So that will allow you to convert it for editing? I haven't tried decompiling any converted models, but I can't see why it wouldn't work. I tried the Rubik's cube and it worked. This effectively converts ZC models to Source, right? Cool. If so we might consider adding this as a tool in the Wiki... It does, but some models (like assassin.mdl, assassin2.mdl and assassin_phase2.mdl) still won't work if converted. Has anyone tested it yet? |
Aug 3 2009, 04:46 AM
#34
This effectively converts ZC models to Source, right? Cool. If so we might consider adding this as a tool in the Wiki... Could you possibly add more stuff do Garry's Mod then? And don't forget the Spider Pig Also, if it does, can it make it possible to convert ZC maps? -------------------- |
Aug 3 2009, 04:58 AM
#35
So if the Rubik's cube worked, can you release it?
Aug 3 2009, 06:19 AM
#36
Also, if it does, can it make it possible to convert ZC maps? I'm investigating this. So if the Rubik's cube worked, can you release it? I just did it as a test then deleted it. It's in zenoclash\zenozoik\props\rubik\ if you want to convert it. |
Aug 3 2009, 07:30 AM
#37
Ok, I'll convert a few models and add them to Gmod.
EDIT:Oh dear, I converted the rubik's cube but forgot to backup, please send me the orginal vvd :/ -------------------- Zeno Clash 2!
Aug 3 2009, 12:22 PM
#38
So if the Rubik's cube worked, can you release it? Isn't that wares? -------------------- |
Aug 3 2009, 01:21 PM
#39
Isn't that wares? I suppose so :/ I can't get it to work though. -------------------- Zeno Clash 2!
Aug 4 2009, 05:08 AM
#40
Verfiy integrity of cache for Zeno Clash, or you can convert the .vvd back.
